2000 Ford Mustang Compressor cycling
2000 FORD MUSTANG
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
INLAND_GUY
Hello, my air conditioning has developed the nasty habit of blowing hot and cold. When I watch the compressor, the clutch will engage for approx 7-8 seconds, then disengage for the same amount of time. This will continue consistently. When I disconnect the a/c pressure switch, the clutch will not engage. Any thoughts? If it is the pressure switch, can this be changed without having to evacuate the system?
Thanks!
Sep 24, 2009 at 12:52 AM
LEGITIMATE007
  • 5,121 POSTS
hi , mostlikey there's not enough pressure in the system which, indicates a small leak, I would first try to top off the system,(least costly), and see what happens, it should cycle less frequently as you fill, use it for a couple of days, if it goes back to cycling frequently then you have a leak, if it cycles less frequently then obviously you dont, if it continues to cycle on and of frequently even after you checked pressure and topped off, then its your switch. I hope I didnt sound to confusing
thanx
joe
Sep 24, 2009 at 12:59 PM
