Air Conditioning problem
1995 Ford Mustang 6 cyl Two Wheel Drive Automatic 150k miles
95 mustang Still tring to get air to blow out vents will only blow hot air out the defrost holes... no matter if i put it on vent or AC or heat its the same temp and it comes from the defrost holes
Some one said a check valve was messed up The ford dealer ship does not even list one
Im sure its a Vaccum line any pointers on where to start and even after i get it to blow correctly Im not sure air is gonna work
UPDATE
I checked lines under dash No vac long story short I found the line was broke at the vaccum block I fixxed it and have Vac all the way up to a splitter with a pig tail in it it has the numbers E4ZF-9C915-AA and E0995b there is Vac going in to it but none comeing out and the air still only blows out the defrost found out part is the Vapor Purge soloind does that even have anything to do with AC
Update Number 2
I kept searching for a Vac line found one unhooked that was coming out firewall by the accumlator.... Could not find where it hooks to so I hooked it to the Purge valve line mentioned above.... and the vents started working So Im sure thats the right line
My question now is Where is the correct place to hook the line I know the purge vavle needs to be hooked up and i dont want a vac leak......
Also when car is on max AC it blows cool air not cold anyway to test Ac myself with out putting car in the shop
Jan 18, 2019 at 12:04 PM
(Merged)
