Heater problem
1999 Ford Mustang V6 Two Wheel Drive Automatic 72000 miles
The fan motor only works on the two upper speeds and not the two lower ones. The Owner's Guide does not show any fuse for the heater motor, but I wonder if there is a fuse or relay for the two lower speeds located anywhere else?
If the fuse/relay is not a valid consideration then what is the next most likely plan of action to consider?
Thank You
Thank You
Dec 5, 2007 at 1:49 PM
