1998 Ford Mustang Transmission noise
1998 FORD MUSTANG
113,000 MILES • V8 • 2WD • MANUAL
SCAPPOLLA
I have 1998 ford mustang 4.6L 5 speed manual trans. I have a noise coming from transmission, kinda hard to explain noise, but when i put pressure on the clutch pedal it disappears. I am assuming its coming from transmission because of this. Do you have an idea on the problem, if so, is it an easy, to "i'm mechanically inclined" and should attempt this repair, or should i take it to a trans shop? Thank you.
Jan 13, 2008 at 11:51 AM
2CARPRO JACK
  • 11,533 POSTS
That is usually the throw-out bearing. Sometimes the input shaft can make noise like that, but it less comon than theT.O bearing
Jan 14, 2008 at 5:07 PM
