1998 ford mustang fuel tank gasket
1998 FORD MUSTANG
CARFIXER7
there is gasket where the gas fill tube enters the gas tank. took everything apart but could not get tube out of tank to replace gasket. wasn't enough room to get it all the way out with the constraints of the frame and the body. has any one replaced one of these before? do you have to remove the gas tank? seems like a lot of work for such a simple repair. any advice would be appreciated, thanks.
Nov 12, 2007 at 12:42 PM
J.SMITH
Yes you do have to drop the gas tank, its not that bad 3 bolts since one is on a hinge. Once you get the tank down the pipe comes right out with a little force =) GL
Nov 27, 2007 at 1:40 PM
