1996 Ford Mustang Pass window goes down but not up
1996 FORD MUSTANG
112,000 MILES • V8 • 2WD • MANUAL
CIGARETTE38
Passenger window on my coup will power down but no power going up. I changed the motor, checked the switches, nothing seems wrong there. Window will not move at all from the master side, only down from the pass side. Drivers window works fine, all 3 switches work fine on the drivers window. I do not understand how the one touch module affects the pass window could this be my problem? Is there anything I can do to confirm one touch module is working?
Thanks
Feb 7, 2009 at 3:41 PM
CIGARETTE38
Problem was found to be a open in the tan/blue wire comming from the master switch to the passenger switch resulting in no ground for the up function. A tip for this would be to unplug the motor so you do not read continuity comming back through the motor. I did not see the open untill I did this.
Feb 9, 2009 at 10:13 AM
