I have had a MIL for the o2 sensors on this car and finally decided to do something about it. I figured with 150000 miles on the car I might as well go ahead and replace all 4 O2 sensors. I replaced them with the correct Motorcraft front and rear sensors (all 3 part numbers). After about 2 days the mil came back on. It was the TPS (which I then replaced and cleared). 2 days later the MIL came back on with the P0141 code. (O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)). I have done some research and it seems that this code is not likely a bad O2 sensor. Can you make any recommendations as to where to start troubleshooting? Also, I am assuming bank one is the passenger side on a 96 mustang.
Dec 22, 2008 at 7:59 PM
