Mustang Cobra, new starter and battery installed. Car won't start but it cranks. When cranking, there is a loud grinding type noise and it appears it is coming from under the car behind the motor. I cranked it for about a minute several different times and it finally fired and ran fine, I shut it off and it makes the same grinding noise and won't start. Almost cranks like the timing is off while the noise is being made then when it did "catch" and start the noise stopped. What could this be? Flywheel, clutch, etc? thank you.
Dec 2, 2007 at 1:12 PM
