1995 Ford Mustang Wheel Smells burn
1995 FORD MUSTANG
226,000 MILES • 6 CYL • 2WD • AUTOMATIC
STANG007
  • 29 POSTS
Hi guys! I have a question for you and I hope you can help me. I own a 1995 Ford Mustang V6 3.8l. My rear seals broked so some oil was spilled on my rear wheel on the left side. We repaired the seal but the rim was still dirty. One day we took the highway and we did about 1hour of highway and when we stopped my rear left wheel smelt burn and was hotter than the others. So I checked if the hand brake was jammed on the rotor but the hand brake is fine. After I though that it was the oil that came hot and smell that. So I took brake cleaner and cleaned the rim. But the other day we took the highway too and same thing but this time my rim was clean. I don't have a clue what the problem is. I hope you guys can help me..
Thanks!
Apr 27, 2008 at 7:36 AM
BMRFIXIT
  • 19,053 POSTS
The shoes had absorb the oil and when braking it will over heat
the solution to your problem is replacing the shoes
on the rear
Apr 27, 2008 at 8:30 AM
