1995 Ford Mustang Poor performance
1995 FORD MUSTANG
WIZZAP
  • 31 POSTS
Engine Performance problem
1995 Ford Mustang 6 cyl Two Wheel Drive Automatic 150k miles
95 mustang performance problem
It started out that when it got to 20 or 30 it would sputter and backfire lightly and drop back down to 10 miles per hour
Now it will only run like 10 miles perhour
Took it to Advance Auto and they checked the codes it said
Bank 1 and 2 Too lean they told me TPS and mass air flow
Took it across the street they checked it same Bank 2 too lean said it was the EGR valve
Took it to a mecanic he put a gauge on the fuel pressure valve it only had 30 lbs at idle and 18 when you reved it up
All these parts are exspensive Is it possible that all of them are bad at once
Where should I stat what do you recommend
Jun 13, 2009 at 12:55 PM
DOCFIXIT
  • 18,828 POSTS
I would go with fuel pump spec is 35-40 psi
Jun 13, 2009 at 1:05 PM
WIZZAP
  • 31 POSTS
When i give it gas should the pressuer on gauge go up or down it was sitting at like 25 to 30 when i reved it up it went to 18
Jun 13, 2009 at 1:10 PM
DOCFIXIT
  • 18,828 POSTS
Pressure should stay at 35-40 look for fuel pressure regulator on fuel rail. Like a silver can with a vacuum line attached. remove line pressure should go up.
Jun 13, 2009 at 1:33 PM
WIZZAP
  • 31 POSTS
[quote:88cdc2add5="Docfixit"]Pressure should stay at 35-40 look for fuel pressure regulator on fuel rail. Like a silver can with a vacuum line attached. remove line pressure should go up.[/quote:88cdc2add5]
don't see one does it kinda look like a disk sorta like a egr valve
Jun 13, 2009 at 1:52 PM
DOCFIXIT
  • 18,828 POSTS
About the size of a silver dollar look at fuel rail silver pipe it will be on the end . Look at the back side of intake toward bulkhead
Jun 13, 2009 at 2:02 PM
WIZZAP
  • 31 POSTS
Ok I found sadley I dont have a fuel checker anymore guess I could try and borrow one ....
If I try and drive the car with that vaccum line unhooked will it do anything when i um hooked it the Rpms sound like they went up a bit
Jun 13, 2009 at 2:13 PM
DOCFIXIT
  • 18,828 POSTS
Won't hurt will be better cause pressure came up. If it runs good and pressuer is 35-40 then regulator faulty
Jun 13, 2009 at 2:15 PM
WIZZAP
  • 31 POSTS
Ok doc gonna run back to town to try it and to test it hope you still around plan to donate more you have been a god send
Jun 13, 2009 at 2:32 PM
WIZZAP
  • 31 POSTS
Well guy I know with the gauge has already closed shop so gauge was a no go.....
However even with the vaccum line off it still did not improve perfomace was it will not get above 15 on or off If you lightly press the gas it might get up to 20 but if you give it any pedal it will die out it never shut completly off just has no power at all
Jun 13, 2009 at 3:13 PM
WIZZAP
  • 31 POSTS
still searching thru forums the more i search the less I get any closer to the problem because I keep getting more and more things that can be wrong ...
Could timing be a issue
Jun 13, 2009 at 3:23 PM
WIZZAP
  • 31 POSTS
I think I may be hopless in getting this fixed for less than what the car is worth
Parets are starting to total up to 500 bucks and I still don't have a clue whats wrong
If I put it in the shop they gonna charge me a arm and leg and do the same thing just change out parts till they get it right
Jun 13, 2009 at 3:34 PM
WIZZAP
  • 31 POSTS
If I donate more will more techs respond Doc seems to be AFK now and he was great
Jun 13, 2009 at 3:58 PM
WIZZAP
  • 31 POSTS
guess my topic is dead no one seems to be posting anymore
Jun 13, 2009 at 9:23 PM
RACEFAN966
  • 5,029 POSTS
OK you are lean bank 1 and 2 so have you cleaned the mass air flow meter? If not get a can of mass air flow cleaner not carb cleaner it is to harsh just mass air flow cleaner. Now you will need to remove the mass air meter. You do this by pulling the air filter and then removing the part with the plug in on it and then clean it with the mass air flow cleaner. Put it back together and let me know how it goes. I have a 98 Mustang and had a lean code did this and fixed it. If any dirt or oil (from over oiling a K&N type filter) will make it give faulse readings. So do this and let me know how it goes. I would also like to know if there are any performance mods. Get back to me and we will go from there.
Jun 20, 2009 at 8:58 AM
