1995 Ford Mustang no spark
1995 FORD MUSTANG
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
MSHROPSHIRE
  • 10 POSTS
When I got this car It had blown head gaskets and warped heads. It would start. I replaced the heads and it wouldn't start. The first problem was the coil had shorted out so I replaced the coil pack and the crank sensor and the ignition control module. I still have no spark. I have traced all the lines and tested them and they are all good. I have 12 volts at the coil and the coil gets warm . I have tried everything I can think of. Any help is greatly appreciated.
Dec 23, 2008 at 9:55 PM
RACEFAN966
  • 5,029 POSTS
Ok first I need some info and the more the better. How did you determine that you have no spark? What all have done and what tests have you performed? How did you test the cranksensor? Have done any scans and if so is there any codes? get back to me with as much as you can and we will go from there.
Dec 26, 2008 at 9:42 AM
MSHROPSHIRE
  • 10 POSTS
I have used a spark tester to confirm no spark. There are no trouble codes. I used a multi-meter to test the crank sensor. I have traced all of the lines in the wire harness back to the disconnect block at the firewall and tested them using a multi meter.
Dec 26, 2008 at 9:54 AM
RACEFAN966
  • 5,029 POSTS
Ok good so far now I need you to do some test on the ignition module on the right front apron. All these tests are with key on engine off, Pin 8 the red wire make sure there is power to it. I also need you to test the PCM for power too, with you digital volt meter with key on engine off check for power between pin 71 and 97. Let me know what you find and we will take it from there ok. Here is a pic of the PCM connector.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_19.jpg
If all this is ok then we need to check the cam sensor under the coil pack this is what initiates firing order and spark.
Dec 26, 2008 at 9:41 PM
MSHROPSHIRE
  • 10 POSTS
I am getting 0.12 as the reading on the pcm harness.
I am getting 12 volts on pin 8 of the ignition control module harness
Dec 27, 2008 at 5:12 PM
MSHROPSHIRE
  • 10 POSTS
I tested further and it turns out that there is NO voltage at the PCM.What do I do now?
Dec 27, 2008 at 6:19 PM
RACEFAN966
  • 5,029 POSTS
I am thinking if the power wire is good then it may be the pcm power relay. This is built into the Constant Control Relay Module. It is mounted on a braket behind the engine coolant reservoir. Check to make sure it didn't get unpluged when you did the heads and check for any damaged wire to it. Let me know how it goes and take it from there.
Dec 28, 2008 at 10:23 PM
MSHROPSHIRE
  • 10 POSTS
I traced the lines and checked the connection and everything was good. While I had the pcm when I turned the ignition on thr fan began running. Now I have 12 volts at the pcm but still no spark. So I replaced the cam position sensor just to make sure it wasn't bad. Still no spark. Is it possible that the relay is bad or that the PCM has shorted out?
Dec 29, 2008 at 7:49 AM
MSHROPSHIRE
  • 10 POSTS
Ok. I checked the wires and they were all ok. I got another CCRM and installed it but there is still no spark. What else could it be besides a bad PCM?
Dec 29, 2008 at 4:29 PM
RACEFAN966
  • 5,029 POSTS
First let me say I am sorry it took a while to get back to you I have been snow blowing like crazy here in north Idaho. I got another foot just today and we have more then 3 feet on the ground and more to come.
With that said yes it could be a bad PCM. With what I can find the test you did should have determind it. If there is power when you check the two term. then the pcm is the only other possibility. I hate to pronounce a pcm bad but it looks like that may be the problem. You did check the ground to pcm right. If you are not sure make sure the ground is good first then make that disition to replace it.
Dec 30, 2008 at 12:01 AM
MSHROPSHIRE
  • 10 POSTS
I understand about the snow. Ok I checked the ground and it was good. So I got another PCM and tried that but I still have no spark. I am completely out of ideas.
Dec 30, 2008 at 12:01 PM
MSHROPSHIRE
  • 10 POSTS
Ok...I found the problem. one of the wires had the insulation burnt off. I fixed that and got it started and I am only running on 3 or four cylinders. I am getting 2 trouble codes. One says that there is a cylinder 3 missfire and the other indicates cylinder 4 misfire. What would cause that??
Dec 30, 2008 at 4:10 PM
RACEFAN966
  • 5,029 POSTS
Ok you need to check the spark plugs and wire for those cylinders and make sure they are good. What it is telling you is that it is not firing on those cylinders. Let me know what you find. Glad you found the wire problem now lets get all 6 runnig.
Dec 30, 2008 at 9:56 PM
MSHROPSHIRE
  • 10 POSTS
I replaced the wires yesterday and I was still getting the code. I replaced the plugs this morning because 2 of them appeared to be fuel fouled.That stopped the codes but it still sounds like a lawnmower engine and it has very little power. The only other things I can think of are maybe the valves didn't get torqued as they should have or the timing chain has jumped. Am I heading in the right direction or do you have a better idea?? I am frustraited beyond belief with this car.
Dec 31, 2008 at 11:58 AM
MSHROPSHIRE
  • 10 POSTS
IT'S RUNNING PERFECT!! The new coil was bad and it wasn't sparking on cylinders 3 and 4. Thanks for all of your help and guidance.
Dec 31, 2008 at 6:29 PM
RACEFAN966
  • 5,029 POSTS
Thats great its to bad it was a defective part so we didn't get into testing it anyway. Thats great glad to hear it is running agin. If there is anything else just ask. Us Mustang owners must stick together. :) Thanks again.
Jan 2, 2009 at 10:07 AM
