1995 Ford Mustang Howling coming from bake brakes
1995 FORD MUSTANG
145,000 MILES • 6 CYL • 2WD • MANUAL
KOOLDUDE0788
  • 8 POSTS
There is a annoying and embarrassing howling noise that comes from my back brakes. (Disk brakes) I already had some one turn the rotors and that fixed the problem for a while until i started to use the E-brake. I dont know if the E-brake is 100% of the problem but im sure its part of it since it seemed to make the problem worse. I seems to make the noise mostly when i start moving and when I'm accelerating and making a sharp turn. They are also squealing really loud but last time i checked the pads where still good. Please help cause I don't want to buy new rotors if its something to do with brake pads or something else.
Apr 25, 2008 at 12:30 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds like the pads are not returning back away from the rotor. Pull them apart and lube the sliding mechanisms and pad contact points..not the pad surface.
https://www.2carpros.com/forum/automotive_pictures/30961_caliper_lubeareas_15.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_caliper_lube_16.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_caliper_lubeareasbrack_15.jpg
This isn't your caliper, but you get the idea, right? May be the quality of the pad as well.
Apr 25, 2008 at 5:36 AM
