1993 Ford Mustang transmission fluid cooler line steel leak
1993 FORD MUSTANG
130,000 MILES • V8 • 2WD • AUTOMATIC
TOMAS_LEWIS90805
my cooler line has a pin hole leak right where it enters the connection on the cooler and fluid is pouring out of it, would it be possible to mabye bypass the cooler? or cut off the little piece where the hole is?
Mar 23, 2010 at 2:24 PM
HMAC300
  • 48,601 POSTS
y don't want to disconnect the line as that comes right from the converter. Best bet would be to repair it, cut it off andeither flare both ends and put in a connector or just shorten it if you can and reflare it and install it in the cooler.
Mar 24, 2010 at 5:10 PM
