1993 Ford Mustang signal and cruise control wiring
1993 FORD MUSTANG
NAY-NAY
Electrical problem
1993 Ford Mustang 4 cyl Two Wheel Drive Automatic
all my lights work wipers work only the signals and cruise control and horn does not work this car has had the steering wheel column and fuse box changed to eliminate the problems but that didnt work where can i find the problem
Apr 22, 2009 at 10:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
Did these problems all initiate at the same time? If not then we will need to troubleshoot each individual component. If so then it is most likely wiring and I will provide you with diagrams to assist with inspecting correct wires. Just let me know if was at same time or diff. times..
Thanks for using 2CarPros.com!
Apr 22, 2009 at 12:24 PM
