It is equipped with an adjustment nut..Make sure the parking brake is fully released.
Place the transmission in N . Raise and safely support the vehicle.
Tighten the adjusting nut against the cable equalizer, causing rear wheel brake drag. Loosen the adjusting nut until the brakes are fully released; the wheel should spin with no drag.
Lower the vehicle and check the operation of the parking brake.
Thanks for using 2CarPros.com!
Mar 11, 2021 at 2:29 PM
