1993 Ford Mustang Backfires when cold
1993 FORD MUSTANG
250,000 MILES • V8 • 2WD • MANUAL
BRIAN JENTSCH
When I fire up the car and take off after warm up, the thing bogs. I floor the gas and it will sputter and do a weird backfire/thump from the front right section of the engine compartment. After that initial backfire, it will run perfectly until I turn it off. Even if I only turn it off to get gas, when I restart, the same thing happens. I am thinking maybe the smog pump?
It has all new temp sensors, oxygen sensors, air filter etc. HELP!
Nov 18, 2008 at 10:46 AM
JAMES W.
  • 2,394 POSTS
The "thumping" noise you are hearing is more commonly know as "lean cough", caused by a fuel lean condition on start up. You may want to check fuel pressure at the fuel rail. Possible fuel regulator problem. Also, fuel filter wasn,t mentioned on your posting.
Nov 18, 2008 at 12:34 PM
