1992 Ford Mustang Passing Gear Engages To Hard
1992 FORD MUSTANG
LOGOS
I have a 1992 Ford Mustang LX 5.0 Liter with an automatic transmission. When the passing gear engages it jerks the whole car. It is going into the gear too hard. I only recently bought the car, but it has been doing this for years. The problem is it may have damaged the differential gearing by slamming into passsing gear so hard. I will probably have to replace the rear end. It can't be good for the drive train to take this king of sudden torgue. The transmission shifts perfectly other than this problem.
Aug 1, 2007 at 11:54 AM
LOGOS
[quote:3991799d12="Logos"]I have a 1992 Ford Mustang LX 5.0 Liter with an automatic transmission. When the passing gear engages it jerks the whole car. It is going into the gear too hard. I only recently bought the car, but it has been doing this for years. The problem is it may have damaged the differential gearing by slamming into passsing gear so hard. I will probably have to replace the rear end. It can't be good for the drive train to take this king of sudden torgue. The transmission shifts perfectly other than this problem. The car has 139,000 miles. This only happens when the the transmission is in OD. [/quote:3991799d12]
Aug 2, 2007 at 11:20 AM
DPWD23
  • 136 POSTS
I would suggest changing the transmission fluid and filter to begin with. I'm not sure which transmision is specific to this model, but if it has a "vacuum modulator" that is a part that can cause a hard thud when it downshifts for more torque. Also if you can get an OBD2 scanner capable of reading vehicle specific codes, it is possible to retrieve all stored codes. You could have a solenoid malfunctioning in that transmission. The good thing is that if that is the cause, most can be replaced without a complete overhaul.
Also please check your transmission mount to make sure it's all in tact. The stress of downshifting causes some major torque to be transfered to the mounts and to the body. You can check all bolts and bushings where the driveline is mounted to the main unibody frame. be sure to check all crossmembers.
Others are welcome to jump in incase I missed anything.
Aug 4, 2007 at 12:49 AM
