1992 Ford Mustang 1992 injectors not working
1992 FORD MUSTANG
KLFITZ
  • 7 POSTS
1992 Ford Mustang V8 Two Wheel Drive Automatic
would a bad pick up coil keep injectors from dumping fuel? We've tried so much and don't want to buy something that won't fix it. Please help!!
Jul 11, 2008 at 9:14 AM
MERLIN2021
  • 17,250 POSTS
No power at injectors? Check the injector fuse, but a bad pick up can cause it. If you dont hear the pump, test the pump like this.
https://www.2carpros.com/forum/automotive_pictures/62217_FP_Test_1.jpg
Grouind the FP and see if the pump runs...
Jul 11, 2008 at 10:18 AM
KLFITZ
  • 7 POSTS
My husband put a wire tester to the injector wires and "shorted" them and they sprayed. We do have fuel pressure to the rail. does is still sound like a bad pick up coil? Thanks.
Jul 11, 2008 at 11:55 AM
MERLIN2021
  • 17,250 POSTS
If the pickup is bad you will not have spark at the plugs, do you? Did he test the pump as I outlined?
Jul 11, 2008 at 3:28 PM
KLFITZ
  • 7 POSTS
yes the pump is working properly and we have spark. What else could it be?
Jul 11, 2008 at 4:40 PM
MERLIN2021
  • 17,250 POSTS
At this point, the pump works, you have pressure in the rail, you have spark, is the compression ok? If yes OHM out the injector harness, you may have some wiring problem...
Jul 11, 2008 at 4:44 PM
MERLIN2021
  • 17,250 POSTS
Do this and count the flashes...Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 11 or 111. Write them down and post here. First do this with the ke on engine off, then again with it running.
https://www.2carpros.com/forum/automotive_pictures/62217_Test_Connector_Pre96_19.jpg
Jul 11, 2008 at 4:48 PM
KLFITZ
  • 7 POSTS
Thanks for your help. Ended up being a bad computer. My husband has worked on a lot of cars but never saw one go bad until now. Again, thanks.
Jul 27, 2008 at 12:52 PM
MERLIN2021
  • 17,250 POSTS
Your welcome.
Jul 27, 2008 at 2:35 PM
