Engine Mechanical problem
1991 Ford Mustang 4 cyl Two Wheel Drive Automatic
Make a long story short. Switched out motors with same size and year from a Ford Ranger. All okay, but won't start. Spray eather in intake and runs about 3 sec. Tries to turn over. Fuel pump kicks on, 40 lbs. pressure. Injector plugs are getting electricity. Regulator is getting fuel. Thinking that somewhere it's not getting ground. Checked the timing, it was good. I just doesn't seem to be getting fuel. Is it possible that something within the PCM or a bad relay. Is there anything that you could suggest to check. We took the wire harness off the car's original motor and hooked to replaceing motor. Made sure the replacing motor had all the same sensors that fit the original harness. This is a teen boys first car and he can't afford much so trying to do as much on his own as can. Very last resort-take to mechanic.
Nov 24, 2009 at 8:51 AM
