Engine Performance problem
1990 Ford Mustang V8 Two Wheel Drive Manual n/a miles
i have a 1990 mustang lx 5.0 with a cobra engine i have problems with it leaning out under acceleration everthing has been replaced every sensor ,fuel pump relays ,ignition ive been through the wiring harness the car was orinallly a 4 cyl car i bought the car after someone had replaced the engine with the cobra engine the car has no emmisions at all on it but the engine ran fine for years the i had a miss at highway speeds then i replaced the ignition pickup in the distriibtor and the fixed that problem new mass air meter calibrated for 24lb injectors, i dont know what else to try i do know when i drive it when its cold it runs fine when it heats up it starts running and idleing bad the after a few minutes when it cools downs while idling it levels out and runs smooth . if u have any suggestions i would appretaite it .when i say i replaced ever sensor thats what i did . ive been over and over everything on it .hope u can help.
clyde
clyde
Nov 7, 2008 at 1:03 PM
