Engine Performance problem
1971 Ford Mustang V8 Two Wheel Drive Automatic
Got a 71 mustang conv. that we put a create motor from jeg's in. The motor is a '87 thru '96 5.0 HO(it came with a 351 cam).Set the #1 piston to TDC on the compression stroke. I was told by the engine manufacture (Blueprint engineering) to besure to use the 351 firing order which I did. With the engine running and warmed up, any timing above 0 deg. BTDC the engine will backfire through the carb when the throttle is cracked quickly but revs smoothly when it is opened slowly. I don't get it.
Sep 8, 2008 at 9:19 PM
