1969 Ford Mustang engine popping
1969 FORD MUSTANG
25,000 MILES • V8 • 2WD • MANUAL
MARTYS69
I have a 1969 boss 429 whose engine is not running so great. Starts fine. Problem is when you acclerate it wants to pop, surge, like it is just not running smoothly. WE have changed the plugs and wires, new points new condensor carb was rebuilt by pony carbs reset timming nothing seems to help. also water level in radiator is always low. It does not run hot (we put in an electric fan) but the water level stays below the core of the radiator. I am not sure if this is part of the problem. Anyway looking for help.
Bob
Dec 8, 2009 at 11:19 AM
If ignition timing is correct -check the fuel filter and fuel pressure-if okay could be the carb's accelerator pump/main metering/power valve problem
Dec 8, 2009 at 11:54 AM
