Hello, Noticed three nights ago that transmission selector light was out. Took old bulb to auto parts and purchased new one. Installed new bulb. Closed battery knife switch and turned ignition on to see if bulb lit. Wire started smoking. Turned off ignition and opened battery connection. Pulled bulb. Wire not smoking now. The wire is blue and red. Checked all accessory items. All work except turn signals. Fuses, flasher pots, and, bulbs all ok. When turn signal is in left turn position and brake pedal depressed, the brake light goes out. Same for the right side. I'd say the smoking wire is indicative of a ground short but I cannot find it. My Chilton's manual doesn't even show the PRND2L light or any wire running that way. Any ideas where to look? Thanks.
Aug 14, 2009 at 6:09 PM
