1965 Ford Mustang rough acceleration
1965 FORD MUSTANG
120,000 MILES • V8 • 2WD • AUTOMATIC
REDPNY
here we go! changed LHS exhaust manifold (cracked) and spark plugs. went for hour drive drove fine. fuelled up (premium), 5-10 minutes down road started stuttering and hiccuping. Got home and dropped fuel and put fresh fuel in thinking it may be bad fuel. Startes fine and idles fine, in park it revs crisp and clean, once in gear it farts and splutters and hesitates. It has poor power. Checked trans fluid fine.
Issues which may or maynot be related:
recently installed rebuilt 4100 autolite carb 4 barrel. can't get secondaries to open. also sometimes there is exhaust fumes coming out of air cleaner.
your help would be greatly appreciated
Feb 8, 2010 at 2:50 AM
Hi redpny, Welcome to 2carpros and TY for the donation.
If you so sure the tranny is not slipping -do below
Check the carb side:
Choke plate fully opens within 3 mins of start up and not closing at idle and part throttle- check float level and power valve, accelerator pump funtioning correctly-should be squirting fuel when throttle is pull back,misrouted vacuum hose or leaking and check fuel pressure.
Check and test the thermostatic aircleaner and heat riser are operating correctly-
Ignition side:
Points -gap/dwell is correct
Vacuum advance and ignition timing
Feb 8, 2010 at 2:17 PM
