2005 Ford Mondeo noise on startup
2005 FORD MONDEO
42,000 MILES • V8 • 2WD • MANUAL
BULLHILL
I get a rattling sound when the engine is started, it last for second or two, then goes away when the oil pressure comes up. the oil pressure is normal, all other systems check normal. this happens when the car has set for six to eight hours. it will not make the sound again until it's park for six to eight hours.
Aug 11, 2010 at 9:01 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The oil filter may be draining back causing the no oil pressure rattle until it picks up pressure, change the filter for a quality non drain back type and see if that helps.
mark (mhpautos)
Aug 11, 2010 at 9:17 AM
