2004 Ford Mondeo air con problem
2004 FORD MONDEO
133,000 MILES • 4 CYL • FWD • MANUAL
TROUBLED831
the air con works for about 5 mins then the blown air temp goes warm, had the air con regased and diagnosed but no fault appeared, could it be high pressure switch?
Jul 18, 2009 at 2:33 AM
MHPAUTOS
  • 31,937 POSTS
HI there, if the system pressures are ok the high pressure switch should not be a problem, are the condenser fans coming on with the air turned on, and is the gap between the condenser & radiator clear of leaf litter and road dirt?
mark (mhpautos)
Jul 18, 2009 at 3:29 AM
