What's problem whit my TCS throttle actuator?Couple days ago TCS stop working then I loose the power and throttle block above 2000rpm.When I disconnected the wiring multi-plug at the TCS actuator I'd solved the problem the power (throttle) is back but steel have the problem with traction when engine is could.Need to warm up the engine to have normal engine power.So where is the problem -TCS throttle actuator or voltage in multi-plug?PLEASE HELP-THANKS VERY MUCH
Apr 14, 2010 at 7:13 AM
