1987 Ford Mondeo
1987 FORD MONDEO
106,432 MILES • 4 CYL • FWD • MANUAL
PAUL.RHODES36
when my car is warm and stood still if you push the accelerator it revs on its own and blows a cloud of smoke out ive replaced turbo unit and throttle position senser and it still does it its a mondeo 1.8 turbo diesel it only started doing it after i stopped using it daily
Feb 14, 2009 at 4:55 AM
DAVE H
  • 13,384 POSTS
there was not a mondeo manufactured in 1987 .. so could you please supply the correct year ! and when you say rev's on its own ? in what way ? does it stick on high rev's ? let me know as much info as possible ?
Feb 14, 2009 at 5:33 AM
PAUL.RHODES36
sorry typing error its a 1997 mondeo 1.8 td when i say revs on its own slightest touch of accelerater and rev counter shoots round to full revs then drops down again instantly but when sat at traffic lights its a bit dangerous managin to controll it at moment but mot due in july and need to sort problem out will make a donatoin if you can help ?
Feb 15, 2009 at 5:23 AM
DAVE H
  • 13,384 POSTS
check all vacuum hoses ..are not leaking .. does the vehicle only do this when running at normal operating temp .. or also when cold ?
Feb 16, 2009 at 1:13 PM
PAUL.RHODES36
yes this only happens at normall running temp ive checked hoses by putting an inline fuel filter on them then running car but nothin comes through im baffled
Feb 16, 2009 at 2:44 PM
DAVE H
  • 13,384 POSTS
do you have a manual for this vehicle .. the mondeo was not released in the USA so i don't have any diagrams .. when i said vacuum hoses in meant for the air intake/throttle body etc. this diagram is for a 3.0L escort just as a reference indicator of what i mean ? .. also could you remove and clean the MAF sensor located on the air filter tube ... i have never seen it cause this sympton but i cannot do any harm to clean it !! let me know
https://www.2carpros.com/forum/automotive_pictures/266999_vac_7.jpg
Feb 16, 2009 at 3:30 PM
