1970 Ford Maverick over charging at high rpm's
1970 FORD MAVERICK
80,000 MILES • V8 • 2WD • AUTOMATIC
DDL1170
I changed the alternator it 's 65 amp. I don't know what the regulator amp's are but the battery boiling out acid and the gauge is showing 16.5 plus amps at high rpms what can I do to correct this problem
Nov 16, 2008 at 9:02 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would be checking the volts at that rpm and replacing the voltage regulator if high, secondly make sure that its not a 24V alternator that has been fitted.
mark (mhpautos)
Nov 16, 2008 at 9:20 PM
