rough iidle
FORD LTD
SASSY SENIOR
I have a 1986 Ford LTD, V6 automatic, with air, 109000 miles. The other day, as I was coming up to a red light, I was stepping on the brake to slow down. My car suddenly acted like I was stepping on the gas instead of the brake. After that, it idled rough, and acted like it really wanted to stall out. What should I check for? Would a tune up help? It hasn't been tuned since last Feb.
Thank you
Sassy
Apr 6, 2006 at 10:31 AM
ANDYMAN
i had this same problem with mine and it was the mass airflow sensor, and it didnt give me no check engine light or anything, hope i helped
Apr 8, 2006 at 8:06 PM
PEPPERMRJ
  • 1,158 POSTS
You can clean it first and see if it helps. Be careful not to damage it just spray it clean with contact cleaner and let it dry first.
Good luck and let us know. :)
Apr 8, 2006 at 10:47 PM
PEPPERMRJ
  • 1,158 POSTS
Check for vacuum leaks also.
