2005 Ford Ka loss of water
2005 FORD KA
BIG SAM
Engine Cooling problem
2005 Ford Ka 4 cyl Two Wheel Drive Manual
few weeks ago car was overheating changed thermo every thing seemed to be ok then at to keep topping bottle up every week .dont think its the gasket .now its blowing hot air even if its set on cold
Jul 31, 2010 at 4:56 AM
If its still overheating check the radiator if its clogged and water pump if its pumping coolant thruout the engine-could also be air in the system that needs bleeding-if it continues consider a block and pressure tests.
now its blowing hot air even if its set on cold: Could be the heater control valve
Jul 31, 2010 at 5:58 AM
