1999 Ford Galaxie LOSSING power when driven over 70
1999 FORD GALAXIE
125,000 MILES • 4 CYL • 2WD • MANUAL
STARRFISH
drives lovly up to 70, lacks power noise like air escaping whistling noise from down by footpedles
Dec 9, 2009 at 1:42 AM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Dec 9, 2009 at 1:52 AM
