1968 Ford Galaxie starting problems
1968 FORD GALAXIE
135,000 MILES • V8 • 2WD • AUTOMATIC
RODSGALAXIE
I am starting to work on a 1968 Galaxie. The car has sat for years. It wouldn't turn over until I ran the shift lever back and forth several times. I got it to turn over about 5 times while checking compression with no plugs. Then it quit again. Battery is good I changed the starter solenoid to no avail. How do I check the starter itself directly?
Rod
Nov 13, 2009 at 5:28 PM
HMAC300
  • 48,601 POSTS
before you start ripping a starter out, if this is an automatic, check the nuetral safety switch to see if it is allowing the power to go through it. A mechanic would know how to test this.
Mar 9, 2010 at 5:10 PM
