The car is currenty undergoing major restoration and during this project I had to remove the key ignition switch from the metal dash. Prior to this the car started from the ignition switch without a problem, now that the switch is just hanging from the wiring it will not start the car at all. Turning the key brings no result, not even a click. You can start the car by jumping across the starter relay. All the wires are connected to the ignition switch! Any ideas?
Thanks
Thanks
Jun 23, 2010 at 3:20 PM
