Greetings, Guys;
I replaced EVERYTHING when I replaced the brake system, even the wheel bearings while I was there. The new brakse lines, "factory replacement" from a Galaxie specialist, leak at almost every fitting; at the wheel cylinders, the rubber flex lines, "T" fittings at the rear differential and front frame rail.....
frustrating.
Is there a tread sealant I should try?
Thanks
Ben
frustrating.
Thanks
Ben
Apr 7, 2010 at 7:00 PM
