should be behind glove compartment area
. Open glove box
2. Push the side walls inward so the rubber stops clear.
3. Detach the retractable string by prying the tab outward. String will retract but is still accessible.
4. Pull box to the floor.
5. Insert a screwdriver in the two slots at each end of the access door and pull out. The right side of the door may need to be pulled downward to get past a non removable tubular part. The small vertical bolts you see are not a part of this process.
6. Reach in with your fingers, fold inward the paper tab at the top of the filter element on the right side and pull filter out. The filter needs to be pulled downward on the right side to get past the tubular part.
7. To insert the filter the right side paper tab again needs to be folded down and maneuvered past the tube.
8. Make sure the hinges at the bottom of the glove box have not detached.
9. Close the glove box, push the sides inward so the stops clear, reattach the retractable string, close the door
May 18, 2010 at 10:06 PM
