2008 Ford Fusion headlamps
2008 FORD FUSION
3,000 MILES • 4 CYL • 2WD • AUTOMATIC
MAGNUM444
how do i change headlamp bulbs. i want to install brighter bulbs in my ford fusion.
Jan 8, 2009 at 12:57 PM
DAVE H
  • 13,384 POSTS
Headlamp Bulb - LH
Remove the air cleaner intake pipe.
Low beam or high beam bulb
Remove the headlamp bulb protective cover.
Remove the headlamp bulb.
Disconnect the electrical connector.
To install, reverse the removal procedure.
Make sure the headlamp bulb protective cover is completely sealed.
Headlamp Bulb - RH
Low beam bulb
With the vehicle in NEUTRAL, position it on a hoist. Remove the screw and the fender splash shield access cover.
High beam bulb, vehicles with ABS
NOTE:For vehicles with a 3.5L engine, remove the engine appearance cover.
Remove the bolt and the windshield washer reservoir filler tube.
High beam bulb, vehicles without ABS
Disconnect the windshield washer reservoir filler tube.
Jan 22, 2009 at 9:57 PM
