2007 Ford Fusion
2007 FORD FUSION
65,000 MILES • 4 CYL • FWD • AUTOMATIC
COMBS1994
do you have to remove the dash to replace a evac temp sensor
Jul 15, 2009 at 7:52 PM
STEVEW84
  • 673 POSTS
1.Remove the instrument panel.
2.Detach the A/C evaporator discharge air temperature sensor.
3.Disconnect the A/C evaporator discharge air temperature sensor electrical connector.
4.Remove the evaporator discharge air temperature sensor.
5.To install, reverse the removal procedure.
Straight from SI
If you want to a picture e-mail me at [email protected] with subject "Fusion Evap Sensor
Jul 15, 2009 at 8:16 PM
