2006 Ford Fusion No Power with Key
2006 FORD FUSION
35,000 MILES • 4 CYL • FWD • AUTOMATIC
RAINB52566
I have a ford fusion sel and nothing works when i have to use the key ., no dash light ( battery light n such ) .i had a wre smell come from under the dash near the door n 30 sec later car stopped .. i have l headlight n all but nothing that works off the key will work ..like car in in park n i have to use bypass on lever to get out of park . afriend of mine seems to think it is a burnt wire from key switch on ward . can that be or can it be a bad fuse ....
Nov 17, 2009 at 3:57 PM
If the smell came from down low, it sounds like something melted down at the ignition switch. Have you checked that?
Oct 21, 2010 at 10:33 AM
