Other Category problem
2006 Ford Fusion V4 Two Wheel Drive Manual 15000 miles
My car is having a high coolent consumption right from the day i bought it.Many checks were done but no external leakge was found.After this cylinder head was examined and was found that the distortion in the head was exceeding the limit of 0.03 mm,it was actually 0.06 mm.After this the head was replaced.But still the problem is the same.I want you to suggest me the next step.How this problem can be solved.I may remind you that intake manifold has been checked and test compression has also been done before it was found that the distortion limit of the head is more than it should be.You may please suggest the next thing to be done in this case.I'll de highly thankful to you.
Dec 2, 2007 at 2:47 AM
