2006 Ford Fusion Coils
2006 FORD FUSION
26,500 MILES • 6 CYL • 4WD • AUTOMATIC
LKF
I have a relatively new car that does not have much mileage. My car stopped in the middle of the street. I was informed that the diagnostic indicated that there is a problem with the coils. The coils need to be replaced. Furthermore, I was informed by the dealer the damage to the coils has caused a problem with my car's computer (PCM). What could have caused this problem? I maintain my car and prior to this incident have had no problems. I also did not notice anything wrong with the car's computer, prior to the car stopping. Also, are either of these repairs considered power train issues?
May 29, 2010 at 9:15 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, First the letters PCM stand for Powertrain Control Module.
Next there are a few thing that could cause a no start problem.
Do you have the Codes or can you get them and post them here. That way I can give you a better answer.
May 30, 2010 at 4:20 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Loretta,
Please reply here in forum and note by email. Thanks
[quote:fea5404f10]
Thank you for your response. The codes provided by the station the car was initially towed to are as follows; PO300,PO301,PO351, PO352,PO353, and PO354. What could have caused this problem? [/quote:fea5404f10]
Ok, P0300 - is multiple cylinder misfire
P0301 - is a misfire in the number 1 cylinder
There are a number of reasons that can cause the misfire.
Plugs
Wires
Vacuum Leak
and more.
The P0351 IGNITION SIGNAL COIL A FAULT
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
Ok, the coils may not be bad it may just be the PCM (Computer)
There are tests that can be run to determine the problem.
Jun 2, 2010 at 2:34 PM
