2006 Ford Fusion
2006 FORD FUSION
82,000 MILES • 4 CYL • FWD • AUTOMATIC
CANNON68
I have a 2006 Ford Fusion 2.3l with automatic transmission. I just replaced the engine with one with 33000 miles on it. After engine installation the transmission will not work. I can shift with the shifter but transmission does nothing. I found a wire plug on the back side where the axles go into transfer case. The 3 wires pulled out of the plug and I can't get the wires back in the wire plug connector. Just wondering if this is the reason my transmission isn't working and if this is something a mechanic can fix if I get the car towed to a shop.
May 30, 2010 at 8:29 PM
BLACKOP555
  • 10,386 POSTS
sounds like that may be the vss. and yes that will cause your problem. and a mechanic ill be able to fix the connector
Jun 1, 2010 at 11:35 AM
