my brakes locking?
2005 FORD FUSION
39,037 MILES • 4 CYL • FWD • MANUAL
FRSPIKEYHEAD
Hi. Just returned car from MOT and full service. The handbrake I knew was bad but the garage has stated that both front discs and pads need replacing, both shoes and drums need replacing and all 4 parts to the handbrake cable need replacing. Among other things. Now the brakes lock up and get hot why?
Nov 13, 2009 at 2:59 AM
KHLOW2008
  • 41,814 POSTS
This happens when the brake booster push rod is adjusted out too far which does no allow the brake master to return fully holding the brakes on . To confirm the issue loosen the brake master mounting bolts 3 turns to see if the car starts to roll again, if so remove the master and adjust the booster push rod inward. Also a brake flex hose can come apart internally causing a short of check valve in the system but this is usually isolated to one brake either front or rear.
Check out the link below.
https://www.2carpros.com/articles/brake-caliper-replacement
Give it a check and let us know what was done to resolve the problem or if you require further assistance.
Mar 18, 2021 at 9:22 AM
