2005 Ford Freestyle Rear safety sensor
2005 FORD FREESTYLE
36,760 MILES • 6 CYL • AWD • AUTOMATIC
JLUCIO
why does the rear safety sensor not work ?
Oct 14, 2009 at 2:50 PM
2CARPRO JACK
  • 11,533 POSTS
Are you refering to the proximity sensor? maybe it was turned off. Those are able to be turned off and on in the main menu. Has any work been done recently?
Oct 16, 2009 at 1:51 PM
JLUCIO
It is the proximity sensor and it has not been worked on at all. I have attempted to turn the sensor on from the console button but it does not respond.
Main menu?? is there an off/on command other than the button on the console? If there is how do I access it?
Thanks
Oct 16, 2009 at 2:52 PM
2CARPRO JACK
  • 11,533 POSTS
Nope, yours is button controlled. Does it have them on the front or just rear of the vehicle? is this a Freestyle SE, Limited or SEL? First be sure the sensor is clean. Then remove the button and see if it is getting continuity when in the on position
Oct 16, 2009 at 4:39 PM
