Try this, record all codes that come up and post please. Sometimes just running this test will recalibrate the gauges and solve the problem...
Instrument Cluster Self-Test To enter the Instrument Cluster Self-Test Mode on the base instrument cluster, press and hold the instrument cluster trip odometer/reset button and turn the ignition switch to the RUN position until tESt appears in the integrated display. On message center clusters, press and hold the message center RESET button and turn the ignition switch to the RUN position until CLUSTER ENGINEER TEST appears in the message center. Press the trip odometer/reset or RESET button to advance through the displays. To exit the self -test mode, turn the ignition switch to the OFF position. If no DTCs related to the concern are retrieved, GO to SYMPTOM CHART.
Jul 19, 2009 at 6:43 AM
