2005 Ford Freestar Camshaft Position Sensor and Speed Senso
2005 FORD FREESTAR
MUSTANGNY75
Engine Mechanical problem
2005 Ford Freestar 6 cyl Front Wheel Drive 42000 miles
Advance Auto retrieved the codes P0715 and P0340 from my Freestar. Where are these sensors located and are they difficult to replace?
Feb 16, 2010 at 12:19 PM
MERLIN2021
  • 17,250 POSTS
There is a Technical Service Bulliten about water intrusion into the PCM, and the tranny vent tube, it's 16 pages long so I will email you a PDF file with the entire TSB. Dont replace anything until you read this, it may be covered by Ford under Fed emisions...Call Ford first!
Feb 16, 2010 at 4:11 PM
MELLIOTT81
Could you email menthis bulletin also. I am having these same codes and problems!
Dec 6, 2014 at 8:36 AM
