Code P0732, transmission will not shift into second gear?
2007 FORD FREESTAR
207,863 MILES • 3.8L • V6 • 2WD • AUTOMATIC
EL_DERICK
  • 8 POSTS
I have gotten a code of P0732, which my car won’t go to second gear it stays in first gear, only goes 25-30 MPH, I have checked the transmission fluid, and it was at its level, and it was clean.
Dec 17, 2024 at 5:16 AM
So this can be that 2nd gear is burnt up or you have a weak turbine shaft speed sensor.
P0732 - Gear 2 Incorrect Ratio This code means the transmission control module (TCM) has detected that the ratio of input speed to output speed does not match the expected ratio for 2nd gear.
Here is the location of the sensor so you can swap it out. Check out the images (below). Please let us know what happens.
Dec 17, 2024 at 12:49 PM
EL_DERICK
  • 8 POSTS
I’ve have changed that sensor and it’s still does the same thing, it won’t change gears.
Dec 21, 2024 at 2:11 PM
Hmm, how is the transmission fluid can you tell if it is burnt or not? You may have a bad transmission and it needs to be replaced. After replacing the sensor did you clear the codes?
Dec 23, 2024 at 12:47 PM
EL_DERICK
  • 8 POSTS
Yes, it clear that code but after I scan it pop up some more codes, B2499, U1900-20, U2023-20, B1676-20, and P1000-FF.
Dec 24, 2024 at 6:28 AM
EL_DERICK
  • 8 POSTS
Transmission fluid is good not burnt or nothing I was thinking of changing it either way?.
Dec 24, 2024 at 6:29 AM
These are battery out of range and communication issues in the CAN and dome light, does this car have modified wiring? Also, can you check the battery voltage? any chance of water damage? Also, with the systems on I would check all fuses.
and
Please go over these guides and get back to us.
Dec 24, 2024 at 11:17 AM
EL_DERICK
  • 8 POSTS
Would any of them codes cause the van not to make gears? But I’m going to go over all that. Thank you.
Dec 24, 2024 at 1:06 PM
These codes will but like I say I would check the battery first which can cause all of these codes.
U1900-20 - CAN Communication Bus Fault - PCM/ABS
U2023-20 - Fault Received from External Node
B1676-20 - Battery Voltage Out of Range
P1000-FF - OBD-II System Checks Incomplete
Let me know :)
Dec 25, 2024 at 10:23 AM
