Engine Idle
FORD FOCUS
MICHAELJB71
I have a 2002 Ford Focus with a 4cyl/2 litre engine and about 70,000 miles on it. It idles very rough in the morning and can take up to a half an hour to throttle back. The mechanic cleaned a lot of carbon deposits out of the throttle plates, but it did not solve the problem. I need to take it back next week, but would like some idea of where we should be looking. I've had a couple suggestions to check the PVC tube for a vaccuum leak and the air control valve. Those sound like good starts, but if anyone has any other suggestions, I would appreciate them.
Mar 8, 2007 at 6:00 PM
KIN CHAN
  • 453 POSTS
did any time the chk engine lite come on?..if so whats the code?.....ask ur mechanic whats the # on short and long term fuel trim showing when the car is cold and after it warm up....msg me when u get these answers...
Mar 8, 2007 at 10:36 PM
MICHAELJB71
The check engine light has never come on. I will check on the other part when I see him. Thank you.
Mar 8, 2007 at 10:56 PM
MIKE H R
  • 3,094 POSTS
you said that the mechanic removed a lot of carbon deposits out of throttle plates. have him check the pcv valve to see if it too is carboned up. he can also check the throttle body for carbon. check the throttle controls to see if they are working properly.
Mar 9, 2007 at 8:42 AM
LAUREN1635
Cleaning the throttle body should have helped out alot but I have a ford as does my brother and his fiance ALL have needed the Idle Air Control valve replaced because of the same issue.... not to hard or expensive to replace yourself but would cost you at least $100 if done by mechanic.
Mar 10, 2007 at 7:41 PM
