car shaking when car is driven 55mph to 65mph i
1955 FORD FOCUS
KARENHANEY
ford focus 40000 miles 2006 stick shift, no sounds, no leaks, repaired mas clyinder in april 2007. when car drives over 55mph to 65mph it starts to shake
Jun 13, 2007 at 10:17 AM
BACKYARDMECHANIC
  • 337 POSTS
The most common cause for front end shake at hiway speeds is the tires being out of balance. Have the tires balanced and the shaking should go away. If it doesn't then it could one of the following like bad tires, struts, or a worn front end. However at 40,000 miles I'am willing to bet it is just a matter of having the tires balanced. It should cost around 10 to 20 dollars per tire. :)
Jun 13, 2007 at 1:29 PM
