Dashboard Rattle! that I can hear the majority of the time I am driving?
2007 FORD FOCUS
7,000 MILES • 4 CYL • FWD • AUTOMATIC
CAUDILLOD
Ok so I have an annoying rattle that I can hear the majority of the time I am driving.. It has been there since I bought the car and has gotten slightly worse. I do not believe it can be heard from the outside. The sound comes from the passenger side of the dashboard (area). It isn't constant though. I mostly hear it when I am accelerating, at any speed, but it tends to get louder the faster I am going. It isn't TOO loud, most people wont notice it unless the radio is off. I also sometimes hear it when I first start the car when it is cold. The sound sounds kind of like wind noise but it isn't, it's a rattle. This is the best description that I can give of it. Please someone help! It is a 2007 ford focus auto.... If it helps any, it doesn't make a difference if I have the air on or not.
Dec 7, 2007 at 1:24 PM
BOSEPHUS
[quote:ab1248d207="CaudilloD"]Other Category problem
2007 Ford Focus 4 cyl Front Wheel Drive Automatic 7000 miles
Ok so I have an annoying rattle that I can hear the majority of the time I am driving.. It has been there since I bought the car and has gotten slightly worse. I do not believe it can be heard from the outside. The sound comes from the passenger side of the dashboard (area). It isn't constant though. I mostly hear it when I am accelerating, at any speed, but it tends to get louder the faster I am going. It isn't TOO loud, most people wont notice it unless the radio is off. I also sometimes hear it when I first start the car when it is cold. The sound sounds kind of like wind noise but it isn't, it's a rattle. This is the best description that I can give of it. Please someone help! It is a 2007 ford focus auto.... If it helps any, it doesn't make a difference if I have the air on or not.[/quote:ab1248d207]
I HAVE EXACTLY THE SAME PROBLEM THE GARAGE ARE NOT FINDING WHERE ITS COMING FROM,HAVE YOU SOLVED IT YET?
Feb 10, 2008 at 2:33 PM
CAUDILLOD
[quote:cd82e86b7e="bosephus"][quote:cd82e86b7e="CaudilloD"]Other Category problem
Ok so I have an annoying rattle that I can hear the majority of the time I am driving.. It has been there since I bought the car and has gotten slightly worse. I do not believe it can be heard from the outside. The sound comes from the passenger side of the dashboard (area). It isn't constant though. I mostly hear it when I am accelerating, at any speed, but it tends to get louder the faster I am going. It isn't TOO loud, most people wont notice it unless the radio is off. I also sometimes hear it when I first start the car when it is cold. The sound sounds kind of like wind noise but it isn't, it's a rattle. This is the best description that I can give of it. Please someone help! It is a 2007 ford focus auto.... If it helps any, it doesn't make a difference if I have the air on or not.[/quote:cd82e86b7e]
I HAVE EXACTLY THE SAME PROBLEM THE GARAGE ARE NOT FINDING WHERE ITS COMING FROM,HAVE YOU SOLVED IT YET?[/quote:cd82e86b7e]
-No I never found out what it was, one of the reasons that I traded in the hunk about a month ago! Good thing I did too because the dealership I went to was about 3 hours away and on my way there the rattle got even worse going up a huge grade! I would recomend to you to try to get a second opinion from a good garage and if still not found, well I guess you have to live with it unless you want to trade it in like I did! I got a Pontiac G6 and lovin' it!
Feb 11, 2008 at 9:26 AM
EHLIN
  • 30 POSTS
to the front on the passenger side you will see what appears to be a little cover over an emergency button of sorts. just take the little plastic cover off and you won't have that noise. i had the same issue with my 2003 focus. i think it is a gas kill in the event of an accident or something.
Jul 1, 2008 at 8:01 PM
BENJAMIN JOHNSTONE
I have a 2006 Ford Focus and my brother had a 2007 Ford Focus. We both had the same issue. My car rattled all over in many places in the dash (so I assumed it was multiple things loose in the dashboard) but it turns out it was a worn engine mount which will make your dash rattle no matter how hard you try to tighten stuff. I wish I knew this when it started to rattle 7 years ago, lol. I replaced the engine mount and it's as quiet as the day I bought it. I hope this helps someone.
Jul 18, 2022 at 2:24 PM
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
Jul 18, 2022 at 4:15 PM
